hi, Is it possible to change output .hex filename at preprocessor time, something like:
#define _BOARD_REV_ 1 ... #if (_BOARD_REV_ == 1) HEX_FILENAME("board_1.hex") #else HEX_FILENAME("board_old.hex") #endif
No. This has absolutely nothing whatsoever to do with the preprocessor, the source code, nor the compiler at all! How about having different Targets in your uVision Project?
hi, yes, Andy - it is exactly what I do for now. I just know that there is a way to alternate *.obj filenames (with OBJECT control) so why not *.hex? Regrads, Oleg
"I just know that there is a way to alternate *.obj filenames (with OBJECT control)" The object file is the compiler's output - so the compiler has control of its name. "so why not *.hex?" Because it has nothing to do with the compiler. once the compiler has generated the object, it has nothing further to do with the process. The Linker takes the objects & combines them into an executable image. The object-to-hex converter takes the Linker output, and converts that to hex. Thus the object-to-hex converter is two stages removed from the Compiler - hence the compiler has no control whatsoever over the name of the generated HEX file! The only thing that has an overall "view" of the whole process is uVision (or whatever other build manager you might be using) - so the only way to do it is through uVision; and that's what the Targets facility is for!
problems like this (and the inability to integrate a decent editor) is exactly the reason I go with .bat files. Oleg, if you want an example, e-mail me and I'll send you one with name substitutions galore. Erik
"problems like this ... is exactly the reason I go with .bat files." In this case, the "problem" has nothing to do with the IDE. There is just simply no way in any environment - make, BAT files, IDE, whatever - that you can ever control the generated HEX file name from the 'C' source code. The final HEX file name is just totally beyond the control of the Compiler.
There is just simply no way in any environment - make, BAT files, IDE, whatever - that you can ever control the generated HEX file name from the 'C' source code oops Erik However there also is no way in uVision to change filenames and such based on one variable which my batch files do seamlessly. Erik
"However there also is no way in uVision to change filenames and such based on one variable" Depends if you count the 'Targets' facility? It's not brilliant (as I've also noted here before), but it might get this job done.
Hi all, I read all the discussions regarding this issue but still it doesn't help me. In my case I have a basic/main code and because this code needs to be programmed in two different targets, I add some "ifndef" commands, where when I compile the code for target X I define X and when I compile the code for target Y I define Y. Until now when I define X or Y I also go to target's options and change output file name to X or Y. I want to do it automatically when I define X or Y. I don't think two targets is the answer here. BAT files I don't know. Can you give me example please? Thanks a lot, Roberto
"I want to do it automatically when I define X or Y. I don't think two targets is the answer here." From what you say there, you are looking at it backwards: When you select Target X, that automatcially defines X for you, and uses the output name X. Isn't that exactly what you want?
