comparing two arrays-values
hi,
i have a xdata unsigned char* a_1[210]
and unsigned char* a_2[210]
Thea are including string value like "21:32 04:34 xyz"
how can i compare this arrays?
what i mean is something like
if (a_1[0] == a_2[0] {
// do something
can somebody help me?
RE
  • Take a look in the manual at the function strcmp().
  • "Thea are including string value like "21:32 04:34 xyz"
    how can i compare this arrays?"
    The standard 'C' library provides functions like strcmp already mentioned for doing simple text comparisons.
    However, if you want to interpret these strings as times, and compare their time values (eg, "earlier than" or "later than"), you will have to write your own comparison functions.
    Hint: start with the most-significant digits...
