Hi, Using LPC2129. I am using timer 0 to interupt on the falling edge of the signal on P0,2 (CAP0.0). The interupt works fine, however I can't seem to clear the 'CR0 Interrupt' Flag after each interrupt, it just loops (always interrupting). I have tried setting T0IR to 0x00000000 but this 'CR0 Interrupt' flag just sets it back again. I can manually untick the flag in debug and this works fine but how do I do it in my code? Any help would be much appreciated. Thanks, Andy.
I can manually untick the flag in debug and this works fine but how do I do it in my code? You need to set the T0IR bit (with a 1) you want to reset. See the DefaultIRQ below.
#include <LPC21xx.H> // Philips Peripheral Registers void DefaultIRQ (void) __irq { T0IR |= 1 << 6; // Reset CC0.2 Interrupt } void main (void) { VICDefVectAddr = (unsigned long) DefaultIRQ; T0CCR |= 1 << 7; // CC2 Falling Edge, CC0.2 T0CCR |= 1 << 8; // Interrupt on CC2 Capture PINSEL1 |= 3 << 0; // Setup P0.16 as CC0.2 input VICIntEnable |= 1 << 4; // Enable Timer 0 Interrupts T0TCR |= 1 << 0; // Counter Enable // Example for LPC2129 // Toggle P0.16 to generate a CC interrupt while (1); }
cheers, works fine. thanks for your help. andy
