All, I'd like to separate all my functions as two qroups, one should located within code address 0x0000--0x4000, while the other is 0x4000--0xFFFF. In assembly, I can use 'ORG', but how do I assign it in C code ? Thanks. SCC
hi, read a bit more about Linker options. In fact, Compiler creates object files, Linker takes them and place into output executable file at appropriate addresses. You may control these addresses with Linker commands. This process is described in A51 manual. Regards, Oleg
