Hi, I am trying to use a float number using microvision2 and the LPC932, but everytime I try to compile it does not. If I make the float number an integer instead, then it works fine. What do I need to make this float number be accepted? Below are the header files I have included. Thanks! #include <Reg932.h> #include <stdio.h> #include <intrins.h> #include <stdlib.h> #include <math.h> #include <string.h> #include <limits.h> #include <assert.h> #include <srom.h> #include <ctype.h> #include <setjmp.h> #include <stdarg.h> #include <stddef.h>
You wouldn't happen to be using an evaluation version of the compiler, would you? http://www.keil.com/demo/limits.htm states that floating point is not supported in the evaluation version.
Hi, I am using the version that comes with the emmulator EPM900 board. It is the 4k version. Thanks
Yep, no floating point with that version. http://www.keil.com/lpc/lpc900_studio.htm
Thanks Dan Henry. It is good to know that!
