Using XC161 DSP Registers like IDX, MAE, MAH or MDL in "Extended Inline Assembler Blocks": Do I have to save and restore (push / pop) this registers - by use in standard linear code ? - by use in interrupts ? - by use in reentrant functions ?
There is no need to save them. They will be saved by interrupts that use the MAC unit. See also: http://www.keil.com/appnotes/files/apnt_172.htm under Register Usage in Assembler Blocks
