When i compile the following code with SRC Directive of this source file, the error occurs. Can anyone help me to deal with it?
unsigned char function(char buffer) { #pragma asm MOV A, R7 MOV R1, A #pragma endasm return 1; }
The manual can help you. That's what you got it for.
Yet again, just read the error message literally: 'asm/endasm' - you know what they are, as you've written them in your code! requires - means something is needed; as this is an error message you should take this as a hint that you have omitted something that is needed. src-control to be active - follows requires, so this is the thing that is required! Look up the SRC control in the Manual
