Convert assembly to Keil C
Assembly code for reading internal EEPROM of AT89S8252:
WMCON DATA 96h ; watchdog and memory control register
EEMEN EQU 00001000b ; EEPROM access enable bit
EEMWE EQU 00010000b ; EEPROM write enable bit
WDTRST EQU 00000010b ; EEPROM RDY/BSY bit
orl WMCON, #EEMEN ; enable EEPROM accesses
mov dptr, #ADDRESS ; address to read
movx a, @dptr ; read EEPROM
xrl WMCON, #EEMEN ; disable EEPROM accesses
I want to convert this code to a C function like this:
unsigned char eepromread(unsigned int address);
Address of data byte in EEPROM (content of DPTR register) can be set easily.
Please tell me how to convert the following instructions to Keil C.
Suppose that the result is saved to a unsigned char variable.
  • Please tell me how to convert the following instructions to Keil C.
    1) WHY, if it works, keep it
    2) If the storage is in xdata, the compiler has to invoke the DPTR.
  • unsigned char eepromread (
    unsigned char retval;
    WMCON |= EEMEN;
    retval = XBYTE[address];
    WMCON &= ~EEMEN;
    return (retval);
    Jon
