The VERSA MIX is a fully integrated mixed-signal microcontroller that provides a "one-chip solution" for a broad range of signal conditioning, data acquisition, processing, and control applications. The VERSA MIX is based on a powerful singlecycle, RISC-based, 8051 microprocessor and an enhanced MAC unit that can be used to perform complex mathematical operations. On-chip analog peripherals such as a 4-channel A/D converter, 4 PWM based D/A converters, a voltage reference, a programmable current source, an uncommitted operational amplifier, software programmable digital potentiometers and programmable switch make the VERSA MIX ideal for analog data acquisition. The inclusion of a full set of digital interfaces such as an enhanced fully configurable SPI, an I2C interface, UARTs and a J1708/RS-485/RS-422 compatible differential transceiver to allow a total system integration solution on one chip. Feature Set o 8051 Compatible RISC performances μProcessor o Single Cycle Instructions o Dual Data Pointers o MAC including Barrel Shifter o Provides DSP Capability o 56KB Flash Program Memory o 1280 Bytes of SRAM o 2 Serial Interface UARTs o Differential Transceiver connected to UART1 J1708/RS-485/RS-422 compatible. o Enhanced SPI interface (Master/Slave) o Fully configurable o Controls up to 4 slave devices o 28 General Purpose I/Os o 2 General Purpose External Interrupt Inputs o Interrupt on port 1 change o 3 Timers / Counters o 3 Capture and Compare Inputs o 4-Channel 12-bit A/D Converter o 1Hz to 10kHz Conversion rate o 0-2.7 Volt Input Range Continuous/One- Shot operation Single or 4-channel conversions o Programmable Interrupt to Processor o On-Chip Voltage Reference o 4 Pulse Width Modulated D/A Converters o Programmable Current Source o Uncommitted Operational Amplifier o 2 Digital Potentiometers o 1 Digitally Controlled Switch o Power Saving Features o Power-on Reset with Brown-Out Detect o watch dog Applications o Automotive Applications o Medical Devices o Industrial Controls/ Measurement Systems o Consumer Products o Instrumentation o Battery Powered SystemsIntelligent Sensors (IEEE 1451.2 Compatible) THANKS tradefair@163.com
Is this a question or an ad? RISC-based 8051, huh? I think that acronym has finally become officially drained of all meaning by marketroids. Keil has a list here: http://www.keil.com/dd/emu/3487.htm
This question would be more appropriately asked of the hardware vendor, its representatives, and distributors. If an emulator is a criterion for your selection of this device, then certainly the aforementioned folks will be most anxious to provide you with that information.
Thank you. But in their Device Support list, there is no VRS1020(GOAL) http://www.isystem.com/Products/Device/MCUsel.htm
http://www.goalforum.com/
