Hello everyone. I decided to try out working in C for a change, but this compiler is really getting on my nerves with it's incessant optimization :/ Can anyone please tell me what i'm doing wrong here: (i'm using optimization level 0) 9: void main() 10: { 11: byte volatile blah; 12: 13: XBYTE[0x7E00] = 0x38; C:0x8030 907E00 MOV DPTR,#0x7E00 C:0x8033 7438 MOV A,#0x38 C:0x8035 F0 MOVX @DPTR,A 14: while(XBYTE[0x7E01] && 0x80) C:0x8036 907E01 MOV DPTR,#0x7E01 C:0x8039 E0 MOVX A,@DPTR C:0x803A FF MOV R7,A C:0x803B EF MOV A,R7 C:0x803C 6004 JZ C:8042 15: { 16: blah = blah+1; C:0x803E 0508 INC 0x08 17: } 18: C:0x8040 80F4 SJMP C:8036 as you can see, the "&& 0x80" bit is optimized out, and thusly this little test program fails.. Cheers, B.A
You're using a LOGICAL and with a non-zero value. That's like saying while (somevar and TRUE) which can in all cases be optimized to while (somevar); and this in turn means that that loop will execute until XBYTE[0x7E01] becomes zero. If what you're trying to do is see if the MSBit of XBYTE[0x7E01] is set, then you want to use the BITWISE and operator as in:
while (XBYTE[0X7E01] & 0x80)
"&&" is the logical AND operator. Any non-zero value is true, so "x && 0x80" has the same logical value as just "x". "0x80" is always true, and "x && TRUE" reduces to "x", which will be true whenever x is non-zero. "&" is the bitwise AND operator, which is probably the one you wanted. This operator performs a bitwise AND. "while (x & 0x80)" will be true as long as the high-order bit of the byte x is set.
DOH! Sorry to have wasted your time gents..
"I decided to try out working in C for a change" I think the lesson here is that "working in C" is not something that you can just "try out" in a moment, on a whim. You need to devote some serious time to study and learning the 'C' programming language!
Yeah, well, at least he didn't decide to just try out C++ for a change :)
I'm with Barry. I learned C yesterday so I think I will learn C++ today. I need to write some ARM code on Moday.
Isn't C++ all a bit passe now? Why not get a Jazelle ARM and go straight to Java...?
Java? Talk about passe. I just describe all my embedded microwave oven control software with xUML and run it on the .NET framework.
"I just describe all my embedded microwave oven control software with xUML and run it on the .NET framework." http://www.ganssle.com/articles/toastallessons.htm
