Hi, has the C compiler/preprocessor the ability to translate "variadic macros" - Macros with a variable parameter list like in the Ansi C99 standard? If not, how can one implement a debug printf (variable parameter count) that is completely removed in the production code is? Description of GNU C: "A macro can be declared to accept a variable number of arguments much as a function can... Here is an example: #define eprintf(...) fprintf (stderr, __VA_ARGS__) This kind of macro is called variadic. When the macro is invoked, all the tokens in its argument list after the last named argument ... of tokens replaces the identifier __VA_ARGS__ in the macro body wherever it appears: eprintf ("%s:%d: ", input_file, lineno) ==> fprintf (stderr, "%s:%d: ", input_file, lineno)"
Search for "TRACE" - this was discussed recently.
