Maybe someone can help me out. I thought I solved the problem, but something else seems to be wrong. I have a project using a 87C51RA+ using only on chip Ram and Rom. I have three _at_ definitions pointing at 0x2000, 0x4000, 0x6000. I have a DIP switch I connected to address 0x6000 which determines the program to run. The program runs OK in the simulator, but on board only parts of the program seem to run. eventhough they more or less use all the same variables. Unfortunately I havn't got a emulator to see what I'm going wrong. Any suggestions on (standard) things people seem to get wrong when things like this happen. I include a piece of code, this is really the only (big) difference between the part that works and the part that doesn't
void timer0(void) interrupt 1 using 3{ d++; m++; TH0 = TH_temp; TL0 = TL_temp; } void delay(x, TH_temp, TL_temp){ m = 0; TH0 = TH_temp; TL0 = TL_temp; while(m < x){} }
You don't show the definition of variable m, which is absolutely crucial to deciding whether this snippet is correct. In particular, you must make sure m is qualified as volatile, because it's modified by two independent threads of execution.
