I wrote a code for the C167 which I want to use with a XC164, but I got lots of error messages as I compiled the code and now I don't have any more ideas to solve this problem... Beside changing the device to XC164CS and the .h-file to XC164.h, what else I have to take care about? Some error-examples: PPF_3.C(35): error C67: 'P1': undefined identifier corresponding code (beneath include-files)
sbit L2_1 = P1^6;
T3CON=0x0003;
Generally speaking, if the compiler tells you that something is undefined, maybe it IS REALLY undefined.... :-) Take a look at the include files XC164.H and REG167.H: peripheral names have been changed, according to the new naming method adopted by Infineon (as stated in Infineon manual). Thus you have to change the names into your source file: i.e. T3CON in C16x becomes GPT12E_T3CON in XC16x. Another solution would be
#define T3CON GPT12E_T3CON
Thank you very much!!! best regards martin
