Fixed adreess constant
I write a funcion named IAP and put it in a fixed adress using de "BL51 Locate" table as below:
Code: ?PR?Switch_Flash?Iap_asm(0x1000)
Now I want to put a constant in a fixed adress. How can I make it together with de directive above? I try to separet both with ";" and "," bu it doesn't work!
Example:
unsigned char code Tab1 = 0x55;
BL51 Locate:
Code: ?PR?Switch_Flash?Iap_asm(0x1000) ; ?CO?Tab1(08000h).
Anybody can help me please?
