why the target hex file NOT generated?
I'm trying to debug my target system using uVision2 MON51. After I changed all install.bat, startup.a51 for code and xdata start address and compiled the code following the instrutions in keil app note 152, I saw all files were compiled well, including myfile.plg, myfile.lnp and myfile.m51. But I could not see the target file myfile.hex which was made everytime compiling without MON51. Can someone provide some info how could it occur? Do I need to load MON51.hex into my IDE? How to load my target and MON51.hex tegother into my board? Thanks.
Frank
