bit bitVal; unsigned char byteVal; : : bitVal = byteVal;
bitVal = byteVal & 0x01 // Equivalent to A or bitVal = (byteVal > 0) // Equivalent to B
I'd expect it to be:
bit bitVar; char charVar = 0xA5; bitVar = charVar; // would be interp. as below, e.g. a boolean treatment of charVar. bitVar = !!charVar;
Some cross-compilers handle it differently, and for that reason, I have always performed the byte-to-integer-bit and byte-to-boolean-bit conversions explicitly to handle either case. For example HI-TECH PICC (obviously for Microchip PIC microcontrollers) abides by a more ANSI-like interpretation, remaining faithful to C's integer conversion (narrowing) rules, and implements it like Andrew's example A. If I had ever thought about how bytes *should* be converted to bits, this is the way a "language lawyer" would probably have specified it (i.e., ANSI-like). Regards, --Dan Henry
Take a look at the following thread for an answer to this question. http://www.keil.com/forum/docs/thread1328.asp#Msg5232 Jon
"Take a look at the following thread for an answer to this question." I'd prefer to be able to look in the manual!! How can I say "Please read the manual" if it's not in the F... Manual!!?? ;-)
