Hi, Has anyone been able to use the external RAM on the Infineon XC16x development board in 16 bit multiplexed mode? I've wrote a small RAM test application that will read and write all memory, but the external RAM always trips up after a few seconds. I suspect the timings may be out on this, since it works most of the time, but will fail eventually. I have the following values: Phase A = 0 cycles Phase B = 0 cycles Phase C = 1 cycle Phase D = 0 cycles Phase E = 0 cycles Phase F read = 1 cycle Phase F write = 0 cycles Does anyone know a set of timing values that work? The micro is an XC164CS running at 40MHz, and the memory chip is a Samsung K6R4016C1D. Incidentally, the RAM test program shows the memory working perfectly in non-multiplexed mode. The timings are different for non-multiplexed, but give worse results when used in multiplexed mode. Any help appreciated! Thanks, Paul.
Hi Paul, that is normally not a problem. The timings you use ,are right. I use exactly the same, without problems. The default values for CS0 are as I know:
CPUCON1= 0003h EBCMOD0= 4032h EBCMOD1= 0000h FCONCS0= 0031h TCONCS0= 0808h
Hi Stefan, Thankyou for your reply. I have checked my setup against yours and I now seem to be having some degree of success. I forgot to mention however, we are using 2 CS lines with no segment address lines, and we also wish to use port 1 as GPIO, so the configuration has been modified accordingly:
CPUCON1= 0003h EBCMOD0= 4020h EBCMOD1= 001Fh FCONCS0= 0031h
Hi Paul, would you please so kindly to inform me, if you have success with your setup. What I am interested in is especially for your EBCMOD1 = 001F setting. With this one we have serious problems, that's why my is 0000. This happens exactly, if we want to use P1H pins as GPIO or as alternate function pins. Thanks in advance Stefan Have a nice weekend
Hi Stefan, Sorry for the delay - I have been away for the last week. I have just returned and I will be looking into this soon. For my project, I want to be able to use the GPIO on P1H. Also, I need the SPI which I think is on P1H as well. I'll let you know how things go! Paul.
Hi Paul, I wrote a simple SPI program for the Infineon board, which is using SSC0 on port 3 If you want I can mail it to you for playing with its code. It is quite good documented. So you have the possibility to programm the on-board ATMEL EEPROM. Stefan
I've now managed to get things working in multiplexed mode, and I am also using the SPI on P1H. Thank you for your offer of software but I don't think it will be necessary since we are programming an EEPROM via this SPI. SSC0 is already being used for another purpose. As for EBCMOD1, we have this set to 0x001F as per the documentation, to allow P1H to be used as GPIO. Although we haven't tested this GPIO yet, we have got the SPI working so things look good so far. Paul.
Hi Paul, thanks for this information, which is usefull to me. May I get your startupfile or an exctract concerning the EBC settings ? This would be very helpfully to me, since I have not yet solved the problem to use EBC and P1H as GPIO (or alternate function). If you would be so kindly, please mail it to stefan_fricke@rutronik.com Best regards and many thanks in advance Stefan
