Hello, I can't set breakpoints in my assembly program if I run it using the monitor (Phytec MM167)! I can step through it and let it run to the cursor line, but setting a breakpoint isn't possible. In simulator mode everything works fine. I'm using a Phytec miniModul-167 with 256kB SRAM and 256kB Flash ROM. I'm working with the evaluation version of uVision2. My trivial program only fills a part of the memory with concurrent values (see below).
NAME fillMem $NOLIST $INCLUDE(REG167.INC) $LIST PAGE3 DGROUP SYSTEM, Stack_s, Data_s ASSUME DPP3:PAGE3 ;------ Stack Section Stack_s SECTION DATA SYSSTACK Start_of_stack: DSW 40 ; Reserve 40 non-init. Top_of_stack: ; words Stack_s ENDS ;------ Data Section Data_s SECTION DATA Tab1: DSW 64 Data_s ENDS ;------ Initializing Code Section Init_s SECTION CODE AT 0 Init PROC jmp Start ; Entry Point Init ENDP Init_s ENDS ;------ Relocatable Code Section Code_s SECTION CODE FillMem PROC Start: mov sp,#top_of_stack ; Fill table Tab1 with values 1 to 64 mov r0,#64 ; Count = 64 mov r1,#1 ; Value = 1 mov r8,#Tab1 ; Adr = Tab1 Loop1: mov [r8],r1 ; (Adr) = Value add r1,#1 ; Value++ add r8,#2 ; Adr = Adr + 2 (Words!) sub r0,#1 ; Count-- jmp cc_nz,Loop1 ; Do While(Count != 0) Ende: jmp Ende ; stop FillMem ENDP Code_s ENDS ; End of code section END
