hai ! I am having a problem in using bit adressable object in Keil C for 89c52 microC.I would be grateful if someone can help me out. I am trying to do the following char bdata temp; // temp is allotted a // byte in the bit // adressable space Can I access the bits corresponding to temp by using temp^0; for instance are these valid. temp^0=1; // set the first bit of temp P0_0 = temp^0; if not, then what's the alternative? Thanks -Adnan
First, before posting code, please read the instructions on the form about using the 'pre' and '/pre' tags. Your question is answered in these threads (among others): http://www.keil.com/forum/docs/thread1132.asp http://www.keil.com/forum/docs/thread3164.asp
