#DEFINE and EXTRN NUMBER are incompatible ???
Dear friends,
Plz help me in solving this bad problem:
PROBLEM DESCRIPTION:
I have a number defined in C and I DONT want to alocate memory in 8051 for this number :
#define myNumber 0x1234
All is well, when i work with myNumber in C for example:
HiByte=myNumber/256;
will translate as expected:
MOV HiByte,#012H ;
No memory alocated for myNumber and stil, C compiler is capable to make calculus based on it.
Happy with that, now i try tu use myNumber (remember defined in C) in ASM.
And that is the problem: I'm unnable to found a method to see myNumberin ASM.
Shortly:
Seems to me that A51 compiler is unable to see a numerical constant declared in C51 with #define directive (but mybe i missing something out, and that's why I ask for your expertize, Dear friends)
An example follows:
//---------file main.c----------------
//I wish to see this number both in C and ASM
//PLZ NOTE: I dont want to reserve memory for myNumber
//i only wish to use it's High Byte in a data memory location
//function defined in ASM which use myNumber
extern  unsigned char GetHiByte(void);
//reserve memory location
unsigned char HiByte;
void main (void)
	HiByte=myNumber/256;//all is well in C
	HiByte=GetHiByte();//dont work in ASM, myNumber is not seen
			   //and is initialized to zero
;-------file func.a51-----------------
?PR?GetHiByte?FUNC? segment code
	EXTRN NUMBER (myNumber)
	public GetHiByte
rseg ?PR?GetHiByte?FUNC?
	using 0
GetHiByte:
	mov r7,#HIGH(myNumber)
	ret
end
Linker errors:
*** WARNING L1: UNRESOLVED EXTERNAL SYMBOL
SYMBOL: MYNUMBER
MODULE: func.obj (FUNC)
*** WARNING L2: REFERENCE MADE TO UNRESOLVED EXTERNAL
SYMBOL: MYNUMBER
ADDRESS: 0016H
  • Your problem is that you don't understand how #define actually works. You should put that #define into a separate file, and #include that both in the C and in the assembler source file.
  • "Your problem is that you don't understand how #define actually works."
    To gain such understanding, read-up on the preprocessor in your 'C' textbook.
    You could also try a 'Search' on this forum for "preprocessor" (or maybe "pre-processor").
  • Thank you verry much,
    Hans-Bernhard Broeker and Andrew Neil
    My problem is SOLVED!!!!
    I found the search in forum more usefull then the C51 manual because Chapter 4 lacks in information on haw preprocessor works.
    The corected code follows:
    //file main.c-------------
    Andrew Neil
    solution
    //myNuber must be seen both by ASM and C
    //so is defined in a comon include file
    #include <comon.h>
    void main (void)
    	HiByte=GetHiByte();
    //file comon.h-------------
    #ifndef _COMON_H_
    #define _COMON_H_
    //I wish to see this number both in ASM and C
    #endif
    ;file func.a51--------------
    ;myNuber must be seen both by ASM and C
    ;so is defined in a comon include file
    $include (comon.h)
    	public GetHiByte
    	using 0
    GetHiByte:
    	mov r7,#HIGH(myNumber)	; Perfectly now!!
    			 	;translated as
    				;MOV  R7,#012H
    	ret
    end
  • "the C51 manual ... Chapter 4 lacks in information on haw preprocessor works."
    That's because it's a Compiler Manual - not a 'C' textbook!
    It is not the job of a Compiler Manual to tech you how to write programs in 'C' - that is the job of a textbook and, preferably, a 'C' programming class.
    See the Preface in the front of the printed C51 Manual (same as the PDF version):
    "This manual describes how to use the Cx51 Optimizing C Compilers to compile C programs for your target 8051 environment ... This manual assumes that you are familiar with the Windows operating system, know how to program 8051 processors, and have a working knowledge of the C programming language." (my emphasis)
    Also:
    "If you have questions about programming in C, or if you would like more
    information about the C programming language, refer to "Books About the C Language" on page 16."
  • You are right Andy Neil,
    Thanks again!!
