Hi, I'm tring to change the port selection structure to use P1 as bidirectional. I use the following C instructions.
SYSCON |= 0x40; IP1 |= 0x80; DIR1 &= 0x00;
change the port selection structure Since this is a non-standard feature it would be extremely helpful if you would mention which derivative you were using Erik
Thank you for your help. I use the SAF-C509-LM. I've found that setting the direction register for P3 to use P3.0 (RXD0) as input just after
SYSCON |= 0x40;
I use the SAF-C509-LM. Made by WHO Erik
Infineon
