At the risk of receiving a good thrashing, I need to ask a basic C code beginner's question: I want to declare/define an array of struct in a .h file that assigns it to xdata memory. /* Struct.h */ xdata struct mode { int x,y,z; }; struct mode xdata type[5]; main.c () { struct_init(); modify_struct(); } struct_init () { type[0].x = 1; type[0].x = 2; type[0].x = 3; etc... } modify_struct() { type[0].x = newvalue; etc... } I'm confused as to how to make the struct visible to multiple files without getting: "Multiple Public Definitions" or "Unresolved External Symbol" etc... Any guidance from the experienced would be appreciated. Thanks
1. Declare and define the struct in exactly one C file. 2. Create an extern declaration in the header file that is included in each C file. Jon
"I want to declare/define" STOP RIGHT THERE! The terms "declare" and "define" have distinct meanings in 'C'; they are not synonyms; they are not interchangeable. A correct understanding of the distinction is fundamental to answering your question. See this thread: http://www.keil.com/forum/docs/thread1847.asp (read it right through) And yes, you were right - this is a basic, standard, plain vanilla 'C' question - nothing specifically to do with 'struct', Keil or their C51 implementation. Consider yourself goodly thrashed! ;-)
Thank you Jon for the simple and brief description of the solution. I was declaring and defining as you described with one exception. In main.c I DEFINED the struct and the array of struct. In a global.h file I only DECLARED the array of struct. I assumed that since I had already DEFINED the struct mode, all the other files would recognize it. Thank you Andy for the additional information and the introductory thrashing!
In a global.h file I only DECLARED the array of struct Wrong. You did not just declare the array of structs --- you defined it, because there's no extern keyword in your supposed declaration. Technically, that makes this a "tentative definition", but effectively, this turns into a definition of the array in every module you #include "struct.h" in. You should almost certainly drop the "xdata" qualifier from the definition of the struct type itself.
