static initialization of extern pointer to function
Hi All,
Could anybody help me out with the following problem? I have a module with the following declarations.
int (*on_CAN_msg)(void);
void CAN_int_handler(void) interrupt 7 using 1 {
	if (on_CAN_msg)
		on_CAN_msg();
Now I have another module:
int CAN_msg_handler(void){
extern int (*on_CAN_msg)(void) = CAN_msg_handler;
I also have the following linker's OVERLAY directive to make sure the compiler knows the correct call sequence:
CAN_int_handler ! (CAN_msg_handler),
main ! (on_CAN_msg)
CAN_msg_handler() doesn't get called. However, when I replace extern int (*on_CAN_msg)(void) = CAN_msg_handler;
with
int main(){
	on_CAN_msg = CAN_msg_handler;
everything seems fine. How can I make this code work without having to assign the handler on the fly?
Thanks in advance,
Sandy
