scanf error when code is > 64K
Hallo,
I face another problem:
I am using Cx51 Ver 7.06
I am using Philips/89C669
I am using ROM(HUGE) (code size maybe > 64K)
I use number of sscanf functions and
until now everything was fine.
Now my code size actually grew more than
64K and then I get this error:
*** ERROR L121: IMPROPER FIXUP
    MODULE:  C:\KEIL\C51\LIB\CS51FPS.LIB (SCANF)
    SEGMENT: ?PR?SCANF?SCANF
    OFFSET:  000043H
If I take out some lines in the program
(not sscanf, but any other lines),
such that code is again < 64K, then I get
no error. Which means the error is not
due to sscanf function but due to code
size (It is my guess :)
What should I do now? I am not possible
to reduce any code. I am still not completely
written the prgram, which means the code
size will increase even more.
mk
  • Are you sure you have the configuration of the tools set up to use the extended (MX) feature of the architecture to have more than 64k of code? Does your startup code set also whatever bits are necessary to enable this mode in the processor?
    It seems perhaps a little unusual that you are using the small memory model with all that code. Of course, you may not need much data space, but just a lot of code.
  • Yes, I have Cx51, Lx51 and so on (actually
    PK51)
    Besides, the problem seems to be only with
    scanf function. I can call many other
    library functions and the code size may
    increase > 64K and still I get no error;
    and the code also works well on my hardware.
    Only if I call scanf, then I get error
    if code is > 64K. (Actually the linker
    complains about scanf, but really I directly
    never call scanf, I only call sscanf.
    Maybe sscanf calls scanf?)
    If sscanf used and code size > 64K, then only
    I see the linker error. If either sscanf
    is removed or if code size is < 64K, then
    everything is ok.
    Yes, I have set the necessary bits for
    using > 64K code. Since my code works even
    if it is > 64K (but without sscanf), it
    means my bit settings are correct (I hope!)
    mk
