my project puts data to the serial port. Only ASCII data is displayed and the hex-mode is not usable. The configuarion is: - Interrupt mode (RX and TX) for the serial channel - Timer-2 for baudrate What can I do?
"the hex-mode is not usable." What exactly do you mean by that? What versions of the tools are you using?
Hi, "the hex-mode is not usable." >>What exactly do you mean by that? It is not possible to switch to HEX-Mode in the serial-window! uVision is switching back to ASCII-Mode. I want to use HEX-Mode. >>What versions of the tools are you using? V7.07 (uVision=2.39) hope it helps ...
"It is not possible to switch to HEX-Mode in the serial-window! uVision is switching back to ASCII-Mode." So it does! :-( I just tried it: 1. right-click in the serial window - 'ASCII' is checked in the pop-up menu; 2. click on 'Hex' - the check mark doesn't seem to move, and the pop-up closes immediately. 3. right-click again in the serial window - to check the setting - 'ASCII' is still checked in the pop-up menu! :-( Looks like a bug, then?
