Hi all! I want to use some sizes of C-structures in assembler. I know that it is possible to use #define statements also in the assembler language, but not something like that:
#define STRUCT_SZ sizeof(TStruct)
The inability to use sizeof() is really only a symptom of a considerably harder problem, I suspect. That real problem is that you cannot use C structs at all from assembly. The assembler not only lacks understanding of their size, it doesn't know anything about structured data types, period. It doesn't understand C struct layout, padding or anything else about structs. What all this means is that you have to choose between essentially these two options: 1) Don't use structs if you want to interface to assembly. 2) Hardcode not just the sizeof(), but also the offsetof() values for elements of the struct in the C-to-ASM interface header files. For case 2), prudence dictates you must check back that the C compiler agress with what you hardcoded. To do that, the usual method would be to have lots of statements like this, in the home C module of that struct:
#include <assert.h> #include <stddef.h> #include "c_to_asm_interface.h" /*...*/ assert(sizeof(struct foo)==SIZEOF_STRUCT_FOO); assert(offsetof(element1, struct foo)==OFFSET_OF_STRUCT_FOO_ELEMENT1); assert(offsetof(element2, struct foo)==OFFSET_OF_STRUCT_FOO_ELEMENT2);
I s'pose another option would be for the assembler to only ever touch the structures in C-called functions, so that 'C' could provide the appropriate address & length at runtime?
