If I declare: #pragma optimize(0) void func1(void) ... void func2(void) ... void func3(void) ... Does this apply only for func1 or for all subsequent functions (i.e. func2,func3,etc)? Thanks, Chip Burns
See the note at the start of the "Control Directives" section in Chapter 2 of the Manual: "Typically, each control directive may be specified only once at the beginning of a source file. If a directive is specified more than once, the compiler generates a fatal error and aborts compilation. Directives that may be specified more than once are so noted in the following sections."
