I woulkd like to put some standard text in all programs. This text needs to be after all other code in memory. I know that I can manually locate the string of text at a particular location. However, I don't want to do this because every time I make changes to the program I will have to manually relocate this string. Is there a way that I can specify that this string of text must be located after all other code? Regards Nick
The advanced linkers (LX51, L251) have an option LAST you can use as the address of a segment in an explicit SEGMENTS() directive. That should do this.
I am using uV2 which uses Linker BL51 V5.03. This doesn't appear to support the LAST option. Any other ideas?
I have found a solution to my problem from reading the following thread: http://www.keil.com/forum/docs/thread2200.asp Under the 'BL51 Locate' Tab, I entered: Code: ?PR*,?CO*,?C_*,?CO?COPYRIGHT It would still be nicer to use the LAST option if available but this will have to do.
"I am using uV2 which uses Linker BL51 V5.03." uVision supports both BL51 and LX51 - you choose which one to use on the 'Device' tab of the Project options.
I just tried using the LX51 linker but got a message that it is a restricted version. Looks like only the PK51 Professional Developer's Kit has the full version of LX51.
"only the PK51 Professional Developer's Kit has the full version of LX51." In fact, only the PK51 has LX51 at all: http://www.keil.com/c51/
