we are using cypress fx-2 development board which has an evaluation version of c-51 compiler (for 8051 microcontroller). we want to include ansi c library functions like fread, fwrite , malloc etc and compile the code and port it into the target board. bcause the above mentioned ansi c library is not supported by c-51, is there any other way of acheiving the ansi c library porting? if so, then please explain how.. also, will it run on the 8051 microcontroller? Urgent reply is appreciated. Regards, mahesh
malloc is supported - see the manual. However, dynamic memory allocation is usually a Bad Idea on embedded systems! fread, fwrite, etc are file functions - so you'll have to implement your own file system. Part of that implementation will included providing appropriate fread, fwrite, etc!
I think Keil does provide an (at least partial) implementation of malloc(), but I'd strongly recommend *not* using malloc() in an 8051 environment unless you have a very good reason. "bcause the above mentioned ansi c library is not supported by c-51, is there any other way of acheiving the ansi c library porting? if so, then please explain how.." Any way other than what? If you need functions that Keil doesn't provide you'll have to write them, in exactly the same way you'll have to write the rest of the code for your project. "also, will it run on the 8051 microcontroller?" That's the general idea. Stefan
"I think Keil does provide an (at least partial) implementation of malloc()" It certainly does! Apart from being a generally Bad Thing on an 8051 (as already noted), be sure to also check out the knowledge base and review the overheads associated with dynamically-allocated memory
library functions like fread, fwrite files on a '51 ??????? Erik
we want to include ansi c library functions like fread, fwrite, ... To add support for fread, fwrite, and so on you must...
so on you must... specify the hardware platform in detail. I am sure it will make a lot Of Keil customers ecstatic if Keil specified a hardware design as a requirement for using theit compiler for embedded processors. It is so amazing how many thinkjj C is C. The difference between PC C and embedderd C is huge. Erik
You have not stated what your "file I/O" requirements are, so I thought I'd throw something else in the mix here. On the few projects where it made sense to do so, I have implemented C's file I/O semantics using an RPC model where fopen, fread, fwrite, etc. on the 8051 side are RPC client stubs marshalling the requests over some communication channel to a RPC server process running on a PC. It works a little like this: The client application calls a local procedure stub instead of the actual code implementing the procedure. Stubs are compiled and linked with the client application. Instead of containing the actual code that implements the remote procedure, the client stub code:
Hi all, Can anyone help me out to create an own file system,since keil does not support file read or write operations. Any URL link regarding this will me more helpful to me. Thanks in advance Chris
Well, the short answer is "implement fopen(), fread(), etc, as appropriate for your device". (Or open(), read(), etc, if you prefer.) The long answer depends on details of your hardware. We have no idea what sort of device your file system is supposed to live on. Flash? A micro disk drive? A remote device over a network? Is the device block structured? Random access? Do you need to add a buffering layer to the I/O, or can the fread() calls just cut right to the device? Is your device complicated enough to require a driver layer to make it go? The design needs to consider how much, if any, of the file system semantics you really need. Do you need to be able to fseek() within a file? Write variable length pieces? Keep track of multiple independent files named with strings? Stored in a hierachical directory structure? Much of this sort of thing tends to be excessive on small embedded systems. (File IDs, for example, could be small integers rather than strings, especially when they're not human-readable or named by humans. A directory tree is only necessary to organize lots and lots of files. And so on.) Implementing non-volatile storage does not mean you have to have a file system. Be sure this is the path you really want to take.
http://www.8052.com/forum/read.phtml?id=82032
