HI I'm new to the tread. I found when using V7.06 constant folding does not appear to work the way I would expect. I would expect that both of these expressions would evaluate to the same answer. However case 1 results in 0. Any options, or is this just a bug! -Jim unsigned short value; value = ADC; value *= 10000L/20000L; //case 1 value = value * 10000L/20000L; //case 2
No bugs, only opinions here. For case 1, (10000L/20000L) == 0, thus (value *= 0) == 0. For case 2, the expression is evaluated as (value * 10000L)/20000L, so as long a value is >= 2, the result will be nonzero.
Any options, or is this just a bug! It's a bug in your expectations. The two assignment statements you present aren't really the same. To make the second one equivalent to the first, you'ld have to write
value = value * (10000L/20000L); //case 2
