HI, I think I have some trouble whith the use of isr_send_signal(), if the task is already in "active state". Please can you tell me what happend in this case : * Interrupt 0 each 100 ms * some times, the fonction mesure()take more time than 100 ms :
/* my exemple*/ : void task_1 (void) _task_ MESURE_priority_ 1 { char i; while (1) { i=os_wait(K_SIG,0,0); if(i==3) { os_clear_signal(EVT_1); Mesure(); } } } void itext0(void) interrupt 0 using 1 { ... isr_send_signal(EVT_1); ... }
HI, I think I have some trouble whith the use of isr_send_signal(): A task is already in a "active state" at the same time when isr_send_signal() to start this task is effective. Please can you tell me what happend in this case : * Interrupt 0 each 100 ms. This programm use 'isr_send_signal' to start task_1, so the mesure() fonction is called each 100 ms. * But some times, the fonction mesure() takes a little more time than 100 ms : So what happends !
/* my example*/ : void task_1 (void) _task_ MESURE_priority_ 1 { char i; while (1) { i=os_wait(K_SIG,0,0); if(i==3) { os_clear_signal(EVT_1); Mesure(); } } } void itext0(void) interrupt 0 using 1 { ... isr_send_signal(EVT_1); ... }
