Use the "CommandLine" to promile my files,how can i config the device?
many thanks
  • All the command-line options are described in the Manauls.
    Or, select the required options in the uVision GUI dialogues, then look at the resulting command-lines that uVision uses - these are shown in the options dialogues.
    Or, run the whole uVision Build process from the command-line - see the Manual
