A question about C data structure (source code)
Source code:
union Time
unsigned char year,month,day;
unsigned char hour,minute,second;
xdata struct structure2
unsigned int FileNum_InDay;
union Time Current;
} GPS;
void GetCurrentTime(unsigned char *ptr1)
Caculated out:
GPS.Current.hour
GPS.Current.minute
GPS.Current.second
unsigned char xdata H_Temp;
unsigned char xdata M_Temp;
unsigned char xdata S_Temp;
float xdata temp1,temp2;
temp1 = DataConver64(ptr1);
temp2 = temp1 / 3600;
H_Temp = temp2;
temp1 = temp2 - H_Temp;
temp2 = temp1 * 60;
M_Temp = temp2;
temp1 = temp2 - M_Temp;
S_Temp = temp1 * 60;
GPS.Current.hour = H_Temp; //a //******* Something Wrong********//
GPS.Current.minute = M_Temp; //b
GPS.Current.second = S_Temp; //c
void Main(void)
unsigned char i,m,hour;
unsigned int xdata POWER1=0,POWER2=0,POWER3= 0;
float xdata Tim = 0;
unsigned char p[8] = { 0x00, 0x00, 0x00, 0x00, 0xFE, 0x74, 0x22, 0x41 };
unsigned char l[4] = { 0x85,0xac,0x41,0x42};
WDTCN = 0x07; // Watchdog Timer Control Register
WDTCN = 0xDE; // Disable WDT
WDTCN = 0xAD;
Tim = DataConver32(l);
Tim = DataConver64(p);
GetCurrentTime(p);
hour = GPS.Current.hour;
//d
The data structure is defined in public.
When the program step to flag 'a' in subroutine,all value is right. To 'b',GPS.Current.hour equal to 0xA7.But ,when step to 'c',the value of GPS.Current.hour change to GPS.Current.minute ,which equal to 0x3b.So,step to 'd' ,the result is that 'hour == 0x3b'.Lately,I found that three variable ( GPS.Current.hour / minute / second ) all be stored at the same location(0x0435) in the assembler. How can I transfer this data_struct to another subroutine?
If a mcu is mutiplex Serial UART, how can I use the macro ' printf ' ?
Thanks for help.
  • Your union Time is just one byte in size, with six different names for this byte. Presumably this is not what you intended. Try something like:
    typedef unsigned char U8;
    typedef unsigned int  U16;
    typedef struct t_Time
        U8 hour;
        U8 minute;
        U8 secound;
    } TIME;
    typedef struct t_Date
        U8 year;
        U8 month;
        U8 day;
    } DATE;
    typedef union t_DateTime
        DATE date;
        TIME time;
    } DateTime;
        U16      FileNum_InDay;
        DateTime Current;
    } GPS;
    printf() is a function that uses the function putchar() to write each character to the serial port. If you want to use different serial ports, you have to provide your own putchar() version. Try a search for "second UART" on this forum.
    Tim
  • Thank you . I will try immediately.
  • "printf() is a function that uses the function putchar() to write each character to the serial port. If you want to use different serial ports, you have to provide your own putchar() version. Try a search for "second UART" on this forum."
    The interrupt-driven serial IO example in the support area shows you how to write your own putchar() & getchar(): http://www.keil.com/download/docs/intsio.zip.asp
