Other compilers and IDE's that I have used in the past have allowed me to "echo" strings or whatever I wanted in the build window. Does anyone out there know if/how I can do this in uVision2? I'll give an example: When I compile a file, say foo.c I want it to print out the various #define flags that are set.. so for example in the past I have done the following: #ifdef _MYDEF_ #pragma ECHO "_MYDEF_ " #endif something like that. I know.. strange request, but because I have so many young engineers working here, I need to be able to figure out if they have turned a flag on! :)
"I need to be able to figure out if they have turned a flag on!" The complete invocation line appears at the top of the listing file - that should do it! C51 doesn't have a #pragma echo - only #pragma error.
"C51 doesn't have a #pragma echo - only #pragma error." It's actually #error. Keil does have #warning though, which will do what you want. Stefan
