How to use the realtime clock on the DS5000T with large memory model
Under "download files" there is an code example "Real-Time Clock Routines for the DS5000T"
Its working when I use the small memory model, but not when I'm just changing to use the large memory model from the IDE. Then it just displays zeroes. I hope someone have a solution to that problem!
Best regards
PL Pang
There is 8k memory on the ds5000t.
I set the mcon = 30 from the command line, before download.
#include <stdio.h>
#include <string.h>
#include <absacc.h>
#include <intrins.h>
typedef unsigned char  BYTE ;
typedef unsigned int   ULONG;
#define ECE2	0x04
sfr MCON = 0xC6;
sfr PCON = 0x87;
sfr TCON = 0x88;
sfr TMOD = 0x89;
sfr TH1  = 0x8D;
sfr SCON = 0x98;
sbit EA   = 0xAF;
sbit TR1  = 0x8E;
sbit TI   = 0x99;
sbit P2_7 = 0xA7;
struct rtclock_st
  unsigned char hsecs;
  unsigned char secs;
  unsigned char minutes;
  unsigned char hours;
  unsigned char day;
  unsigned char date;
  unsigned char month;
  unsigned char year;
extern code char *day_of_week [];
unsigned char rtc_read_byte (void);
void rtc_write_byte (
  unsigned char val);
void rtclock_initialize (void);
void rtclock_stop (void);
void rtclock_get (
  struct rtclock_st *rtc);
void rtclock_set (
#define INT_DISABLE	EA = 0
#define INT_ENABLE 	EA = 1
#define INT_SAVE	{unsigned char intsave = EA	/* save ints */
#define INT_RESTORE	EA = intsave;} 			/* restore ints */
#define RTC_READ	XBYTE [0x0004]
#define RTC_WRITE(b)	XBYTE [0x0000 | ((b) & 0x0001)]
static code char error_date [] = "Date Error";
code char *day_of_week [] =
  "Sunday",
  "Saturday",
  error_date,
  error_date,
  error_date,
register unsigned char i;
register unsigned char dat;
MCON |= ECE2;
dat = 0;
for (i = 0; i < 8; i++)
  dat >>= 1;
  dat &= 0x7F;
  dat |= (RTC_READ & 0x80);
MCON &= ~ECE2;
return (dat);
  unsigned char val)
register unsigned char i;//register meget brugt var
register unsigned char dummy;
MCON |= ECE2;
  dummy = RTC_WRITE(val);		/* ignore warnings */
  val >>= 1;
MCON &= ~ECE2;
static void rtc_reset (void)
for (i = 0; i < 9; i++)
  rtc_read_byte ();
static void rtc_init (void)
dat = 0xC5;
for (i = 0; i < 4; i++)
  rtc_write_byte (dat);
  dat ^= 0xFF;
  dat = _crol_ (dat,4);
register unsigned char rtbuf [8];// indfort register
INT_SAVE;
INT_DISABLE;
rtc_reset ();
INT_RESTORE;
INT_SAVE;
INT_DISABLE;
rtc_init ();
  rtbuf [i] = rtc_read_byte ();
INT_RESTORE;
if (((rtbuf [4] & 0x20) == 0x20) ||		/* if OSC is stopped */
    ((rtbuf [3] & 0x80) == 0x80))		/* if time is 12 hour mode */
  rtbuf [4] &= ~0x20;
  rtbuf [3] &= ~0x80;
  INT_SAVE;
  INT_DISABLE;
  rtc_init ();
    rtc_write_byte (rtbuf [i]);
  INT_RESTORE;
INT_SAVE;
INT_DISABLE;
rtc_reset ();
INT_RESTORE;
#if 0
xdata unsigned char rtbuf [8];
INT_SAVE;
INT_DISABLE;
rtc_reset ();
INT_RESTORE;
INT_SAVE;
INT_DISABLE;
rtc_init ();
INT_RESTORE;
INT_SAVE;
INT_DISABLE;
rtc_reset ();
INT_RESTORE;
if ((rtbuf [4] & 0x20) == 0)			/* if OSC is not stopped */
  rtbuf [4] |= 0x20;
  INT_SAVE;
  INT_DISABLE;
  rtc_init ();
  INT_RESTORE;
INT_SAVE;
INT_DISABLE;
rtc_reset ();
INT_RESTORE;
#endif
void rtclock_get(struct rtclock_st *rtc)
INT_SAVE;
INT_DISABLE;
rtc_reset ();
INT_RESTORE;
INT_SAVE;
INT_DISABLE;
rtc_init ();
INT_RESTORE;
INT_SAVE;
INT_DISABLE;
rtc_reset ();
INT_RESTORE;
rtc->hsecs = (((rtbuf [0] & 0xF0) >> 4) * 10) + (rtbuf [0] & 0x0F);//bcd til hex
rtc->secs = (((rtbuf [1] & 0x70) >> 4) * 10) + (rtbuf [1] & 0x0F);
rtc->minutes = (((rtbuf [2] & 0x70) >> 4) * 10) + (rtbuf [2] & 0x0F);
rtc->hours = (((rtbuf [3] & 0x30) >> 4) * 10) + (rtbuf [3] & 0x0F);
rtc->day = (rtbuf [4] & 0x07);
rtc->date = (((rtbuf [5] & 0x30) >> 4) * 10) + (rtbuf [5] & 0x0F);
rtc->month = (((rtbuf [6] & 0x10) >> 4) * 10) + (rtbuf [6] & 0x0F);
rtc->year = (((rtbuf [7] & 0xF0) >> 4) * 10) + (rtbuf [7] & 0x0F);
void rtclock_set (
rtbuf [0] = (((rtc->hsecs / 10) & 0x0F) << 4) | (rtc->hsecs % 10);
rtbuf [1] = (((rtc->secs / 10) & 0x07) << 4) | (rtc->secs % 10);
rtbuf [2] = (((rtc->minutes / 10) & 0x07) << 4) | (rtc->minutes % 10);
rtbuf [3] = (((rtc->hours / 10) & 0x03) << 4) | (rtc->hours % 10);
rtbuf [4] = (rtc->day & 7);
rtbuf [5] = (((rtc->date / 10) & 0x03) << 4) | (rtc->date % 10);
rtbuf [6] = (((rtc->month / 10) & 0x01) << 4) | (rtc->month % 10);
rtbuf [7] = (((rtc->year / 10) & 0x0F) << 4) | (rtc->year % 10);
INT_SAVE;
INT_DISABLE;
rtc_reset ();
INT_RESTORE;
INT_SAVE;
INT_DISABLE;
rtc_init ();
INT_RESTORE;
INT_SAVE;
INT_DISABLE;
rtc_reset ();
INT_RESTORE;
void main (void) {
  struct rtclock_st rtc;
  ULONG timeout = 10;
  TMOD |= 0x21;
  SCON  = 0x50;
  TH1   = 253;
  TR1   = 1;
  TI    = 1;
  PCON = 0x80;
  P2_7 = 0;
while (1)
		if (--timeout == 0)
		  rtclock_get (&rtc);
		  timeout = 5;
		  printf ("Tid: ");
		  printf ("%02.2u:", (unsigned) rtc.hours);
		  printf ("%02.2u:", (unsigned) rtc.minutes);
		  printf ("%02.2u.", (unsigned) rtc.secs);
		  printf ("%02.2u\n",(unsigned) rtc.hsecs);
		  printf ("Dato: ");
		  printf ("%02.2u/", (unsigned) rtc.date);
		  printf ("%02.2u/", (unsigned) rtc.month);
		  printf ("%02.2u  ",(unsigned) rtc.year);
		  printf ("%s\n", day_of_week [rtc.day]);
