hi all! i'd like to locate a variable (e.g. version number) at a fixed location in ROM, so the firmware can check the userware's version @ startup! userware: int version = 1; // locate this @ 0x1000 - but how ?! firmware: if (*((int*)0x1000) != 1) { DisplayErrorMessage(); } how can I achieve this using C166/L166 ?! thanks in advance for any help... Matthias
Ah, yet another request from someone who wants to use the _at_ keyword with an initialiser. Matthias, this has been discussed many times on the forum. It can be done but not easily. Search for the _at_ keyword. Stefan
Hi Matthias, I always use the following way to achieve what you want to do: 1. I create a single file named version.c In this file I only have the following definitions unsigned char const far FirmwareVersion[] = {030731}; 2. Then I locate this file to a specific memory location, using the locater directive ?FC?VERSION%FCONST (0x57FE0) in the user section of the L166 locate tab of the options window. (in this example this is a far memory location, but this depends from your memory layout). 3. I fetch this date in a c-function as follows: fmemcpy(TempBuf,0x57FE0,6); TempBuf is then filled with the string "030731". Maybe this works for you. regards Uwe
