i am getting "A42 error : UNDEFINED IDENTIFIER" error when compiling an assembly module. when i click on the error it indicates it to statement that contains the defined variables. i am compiling for XC164CS controller the part of the code where i am getting the error is inserted below.
;FUNCTION: FirstSample ----------------------------------------------------------------------------------------------------- public FirstSample FirstSample proc ;Set next Sample routine -> mov SampleRout,#SecondSample
You will find a list of MOV in all its variations here: http://www.8052.com/51mov.phtml However, I would suspect that this is not your problem. We would really need to see those definitions of yours to offer further advice.
Hi, http://www.keil.com/dd/docs/datashts/infineon/c166ism.pdf Have you written programs before or is this your first time... Rgds Raj Shetgar
