Hi, there, The malloc always allocate memory at the tail of the memory initialized by init_mempool(). How to make "malloc()" allocate memory from the beginning of the initialized memory? In details, suppose running following code fragment,
byte xdata *M1; byte xdata *M2; init_mempool (&XBYTE [0x10], 0x1000); M1 = (byte xdata *) malloc (500); M2 = (byte xdata *) malloc (100);
Write your own implementation of malloc/free? In this case you even get to call them whatever you like, say my_malloc/my_free :-) There are plenty of resources on the Internet that will describe how that can be accomplished, not to mention Keil's implementation. - mike
The problem is in how you're trying to use malloc(), not in how it's implemented. If it makes a difference where in memory your block of memory is placed, then you shouldn't be using an malloc()-like function to allocate it. OTOH, I'll refuse to believe it actually makes a difference until you show proof to the contrary.
Actually, my scenario is to migrate some codes from another platform to 8052. The codes assume that the malloc starts from the beginning of the available memory. Thank you two for the suggestion. I will make a decision, either (1) re-implement malloc(), or (2) change the way that the current codes use malloc(). If malloc() is not used too often in the current code, probably I will go with the second solution. thanks, Kan
"The codes assume that the malloc starts from the beginning of the available memory." But, as Hans-Berhard said, does it actually make any difference whether or not this is true? It shouldn't, since there is no guarantee that it's true! Can you explain why it makes a difference? This should immediately be flashing big red lights and sounding loud warning bells: if your code is making this blatantly unwarranted assumption, what others are going to be lurking deeper down... Time to start adding contingency to your project plan, methinks! "(2) change the way that the current codes use malloc()." Particularly on an 8051 target, the best idea would probably be to change it to stop using malloc() altogether!! I have done this in the past, and it wasn't that hard. You may well find that directly accessing statically-allocated data gives you both improved performance and reduced code size (rather than having to go via pointers). Again, on an 8051 this could be significant.
Hi, there, Actually, my previous understanding was not correct. The codes don't have the erroneous assumption that the malloc must start from the beginning of the memory. What happened yesterday was that when I init_mempool(), I didn't assign an aligned value to be the size of initialized memory(0xFF00). Hence, M1 is not the expected 0xFD0C, instead it is 0xFD1C. And then M2 is not 0xFF00, but 0xFF10 which is out of the available memory. After I changed the init_mempool size to be 0xFE00, the problem is solved.
init_mempool (&XBYTE [0x10], 0xFF00); M1 = (byte xdata *) malloc (500); M2 = M1 + 500;
