Hi, can somebody help me with the right setup for using the the autobaud detection unit the right way. I have problems with the generally steps to propperly setting up the ASC. Also a more detailed description of the module as it is in the manuals is welcome. Thanks Stefan
Stefan, If you're talking about the auto-baud in the bootstrap, it uses a free-running timer (#6 I believe). The Rx input is monitored until it drops using a tight loop. Then the timer is started and the Rx input is monitored until it goes high. The timer is read and the baud rate divisor is calculated. It requires the first byte received to be the following: 1 start bit 8 data bits = 0x00 1 stop bit no parity. The actual assembly code for the 167CR series was given in a book on the '166 by ST. This is an early version of code I included in my boot system to emulate the bootstrap mode, allowing debugging on a production system. I don't have a copy of the latest available since I'm not at work.
Fake_Bootstrap PROC NEAR MOV CP, #0FA00h ;Init to reset values MOV STKUN, #0FFFFh ;Leave Ext bus controls alone (for now) MOV STKOV, #0000h MOV SP, #0FA40h MOV STKUN, #0FA40h MOV STKOV, #0FA0Ch MOV DPP0, #0000 MOV DPP1, #0001 MOV DPP2, #0002 MOV DPP3, #0003 MOV T6CON, #0000 ;Init baud rate detector MOV T6, #0000 BCLR DP3.11 ;Rx = Input BTSTRP1: ;while ( ! ~Rx_Port ) // Start bit detect JB P3.11, BTSTRP1 ; continue; BSET T6R ;Baud timer = Running BTSTRP2: ;while ( ~Rx_Port ) // Stop bit detect JNB P3.11, BTSTRP2 ; continue; BCLR T6R ;Baud timer = Stopped MOV R1, #36 MOV MDL, T6 ;BRG = ((T6/36)) / 2 - 1 DIVU R1 MOV R2, MDL ROR R2, #1 JMPR cc_C, BTSTRP3 ; round result SUB R2, #0001 BTSTRP3: MOV S0BG, R2 ;Init serial port BSET P3.10 BSET DP3.10 MOV S0RIC, #0000 MOV S0CON, #8011h ;Enable MOV S0TBUF, #00C5h ;Transmit Ack code for '167 MOV R0, #0FA40h ;BYTE *p_Byte = bootstrap_Base; BTSTRP4: ;do { JNB S0RIR, BTSTRP4 ; while ( ! rx_Byte ) ; continue; MOVB [R0], S0RBUF ; *p_Byte++ = rx_Byte; BCLR S0RIR CMPI1 R0, #0FA60h JMPR cc_ULT, BTSTRP4 ;} while ( p_Byte < bootstrap_Top ); JMPA cc_UC, 0FA40h ;goto( bootstrap_Base ); Fake_Bootstrap ENDP
Hi Scott, thanks for this, but the autobaud detection in XC16x derivatives seems to have a little bit other function. A timer should be used, but you can select nine different baud rates before you start the detection. I found a good description with the APNOTE DS1 (June 2001) from Infineon for the C161U and C165UTAH. This show the way more detailed and uses timer 3. I will adapt this and your code hint. Stefan
