Could anyone enlighten me on pointer arithmetic please? Assigning a constant is fine, but a warning is generated when using a variable. (The code does do what I expect though.) The warning is : 'long' converted to 'xhuge' pointer
void Test() { long x; char xhuge *ptr; x=2; ptr = 0x80000 + 0x01; // no-warning ptr = 0x80000 + x; // warning generated x = 0x80000; ptr += x; // no-warning ptr = x; // warning generated }
Explicit cast to a pointer type will suppress the warning:
ptr = (char xhuge*)(0x80000 + x);
ptr += x;
Thanks! Andy
