uVision2 Linker, memory for ICODE, FCODE...
Hi..
I use an infineon xc167ci without module. I program it using infineon memtool. I can erase the flash, but I cannot program it. On uVision2 "OPTIONS FOR TAGRGET TARGET1=>L166MISC" there is a linker control string determing how memory of the xc167ci is used. The memory location for program memory is 0xC00000 -> 0xC1FFFF(Datasheet), but uVision always writes some code to 0x018000 -> 0x01803B. I can see that in memtool. The linker control string allows e.g. FCODE, FCONST, HCONST,... to write something to this area. But memtool says error: check memory mapping. What do I have to do? Does that have anything to do with startup stuff, for I use no minimodul, so maybe there's something wrong with pu- or pd-resistors.
  • Hi Erwin,
    concerning the ON-CHIP FLASH, ensure
    you have set under "Options for Target" ->
    "Target" use on-chip ROM(128KB)
    use on-chip XRAM (0xC000-0xCFFF)
    If no external RAM or other memory the
    external memory entrys should be empty.
    Than under Linker -> "L166 Misc" only
    do the entry for the vector table as 0xC00000
    Thats all.
    But please check your startup file to be sure EBC is enabled.
    At older versions the userstack was placed in NCODE area, so have look at M66-map file
    and use the USERSTACKDPP3 directive (C166 manual) if necessary.
    For the memtool check out you have selected the right target ( differences between step AA,AB ... )
    Stefan
  • Hi Stefan..
    Thanks for your answer.
    I have done as you said, but it did not help.
    EBC is enabled, and all uVision instructions are as you said they should be.
    As I checked the M66-File, I found out, that the main-routine is linked to 0x18002H
    018002H main LABEL --- FCODE ?PR? test
    The userstack is in 0x00C000H, what seems to be ok.
    What can I do to link the main-routine somewhere to 0x00C000H?
    And what are the differences between AB and AC in memtool?
    Thanks,
    Holger
  • Mhmm,
    did you set small memory model for your target ?
    I wonder that you have FCODE - that
    indicates that your program is an area located where normally a external memory would be.
    If you do it right than you will see
    NCODE ?PR?test.
    Userstack is ok.
    Otherwise I need your map file or
    some more informations.
    Stefan
  • No, the memory model is large.
    If you want you can mail your Email-Adress to
    eins12000@yahoo.de
    So I can send you the files you need.
    Erwin
