Hi, I need to set pins 6, 7 and 0 as outputs on port1 of the lpc932. Pins 5, 4, 3, 2 and 1 will be inputs. Below is the configuration I have done, but for some reason pin 3 which is the INT0 is not high (input) as it should be. can you please check my configuration below. I read the data sheet and user manual, and I do not think I need an external pull up resistor do I? P1M1 = 0x08; // Push-pull all except rst, int0, int1, and RX P1M2 = 0xC1;
Is it being pulled down by whatever is connected to it? Stefan
Thanks Stefan, but the pin has nothing connected to it and it is still low. Therefore the interrupt is not working at all.
you set the pin to input which leave the pin floating, if you want to see it high, you must set it to quasi-bidirectional Erik
Got it Erik. Thanks
Erik, can I configure pin 3 on port 1 quasi-bid-irectional and then make it high, so that it looks as an input? The datasheets say can be input-only or Open Drain.
quasi-bidirectional is the standard/old fashioned '51 port config. refer to "the bible" for info. Erik
