Hello, I'm just trying to get started with the development of some software for an Infineon XC161CJ using the uVision2 Toolset. My first attempt was to get a Display via I2C running (161 master, Display Slave, just write on it), so I used Dave to generate a basic Startup-Config and simply used some of its predefines macros to set up the i2C-communication. What other did one expect than this to fail. My problem is I do not know how to debug. I wanted to use the Memory Window of the Debugger and have a look if the Registers are set properly and if I get an acknowledge from the slave, but I do not get any Information from the memory area, where I expect the registers to be. The I2C is initialized by --- IIC_CON = 0x0008; // load I2C system control register -> 7Bit-Addr,Single-Master,Ack active, 1Byte Transmit-Buffer IIC_ADR = 0x0000; // load I2C address control register IIC_CFG = 0x3133; // load I2C bus control register -> 00110001(=49=baudrate prescale) 0(reserved) 011(scl10) 0(reserved) 011(sda10) IIC_ST = 0x0000; // load I2C status register ALTSEL0P9 |= 0x000F; // select alternate output function ALTSEL1P9 |= 0x0001; // select alternate output function DP9 = (DP9 & ~(uword)0x000F) | 0x000F; //set direction register --- when I watch the Memory Window at the corresponding adresses when IIC_CON is written (#define IIC_CON (*((uword volatile *) 0xE602)) I cannot see any changes, even when I change the value by hand in the Memory Window, after the next instruction its reset to the previous value, i.e. 0x0000. Writing and reading to the memory area of standard-io-pins works fine, so it does watching it in the Memory Window of the debugger (for example #define P9 (*((uword volatile *) 0xFF16)) Anyone a suggestion where to start searching for the problem ? Btw. is there any book or manual suitable for beginners ? Thanks a lot for your replys
Not that this will help you current problem, just the next one that will come along: there are some i2c to rs232 hardware converters. Get some, rig a computer as a dumb terminal, and monitior the traffic.
Thanks for your reply, but that doesn't help me much. It would be a start for me to know how to access a XSFR. Directly adressing a SFR works, but the same for the XSFR seems not, 'cause I cannot see the assignments I made in the Memory Window while debugging and the code does not work. works (can trace this in the Memory window): DP3 = 0xAAAA; //(*((uword volatile*) 0xFFC6)) does not work: IIC_ADR = 0x00FF; //(*((uword volatile *)0xE606)) Even though the Infineon manual says: "Accesses to registers in the XSFR area use 16-bit addresses and require no specific addressing modes or precautions." Can it be, that anything is wrong with the initialization of the I2C-Module and the CPU therefore protects the registers from being written ?
well, I don't know why but I need to reset the controller by hardware after flashing, then start the debug session and then I (most times) get the correct values...
