Linker warning suppression
Is there a means of supressing linker generated warnings? I realise they're there for a reason, but this one's deliberate.
I forget the error code, but it's concerned with the location of an interrupt routine within a code bank. It never gets called in a bank switched context, but the routine is copied across to RAM as part of a flash download routine.
Thanks,
David
