Debug ok but hexfile not.
I am playing with demo version of the Keil µVersion 2.03 and the
Infineon SK-167SR. Also , I am not very familair with in C, which
makes thinks not easier for me.
For me the problem is rather strange. During a debug session
almost every thing is runining fine, but if i let the same programm
run from the flash of the board it does not.
here is (not) working code
void main(void)
unsigned char num_str[6];
... do soemthing ...
write_string(num_str,1);
void write_string(char * s, unsigned char line)
unsigned int i;
if (line == 1) LCD_CNTL = 0x80;
wait(30000);
for (i=0; i<strlen(s); i++)
LCD_DATA = s[i];
wait(300);
During debuging this is working perfectly. It shows some data on a LCD,
but the same program running from flash, writes "only" black squares
on the LCD (the complete fist line on my 20*2 LCD).
For me it is quite hard to find the reason for this behavior.
thanks in advance,
Thomas
  • void main(void)
    What happens after write_string returns?
    If your program returns from main, then it's no surprise that it doesn't work when you run it from FLASH.
    Add a while (1) before the final curly brace in the main function. (Embedded programs never exit).
    Jon
  • Hi Jon and all other,
    sorry Jon, the problem is not this simple. I did'nt want to post all my
    rocky code here, the while(1) code is already include there.
    The problem is a little bit more complicated. I try to explain:
    --- this is my theory ---
    unsigned char xhuge num_str[6];
    The compiler should create a array field of 6 chars somewhere in the
    memory. The memory on the starterkit starts @ adress 0 with 128 kb
    Flash and continued with 64 kb RAM.
    It is likely the compiler will put this field somewhere in the ram area.
    The pointer of this field should be passed to the function write_string.
    This happens ONLY if the programm runs an the debug modus but it does
    not if the program runs from flash.
    During debuging, programm and data code have to be together in the
    64 KB RAM area but, but if it run from flash there are likely to be apart
    by around 128 KB. Then the function write_string does not get the
    right postion of the char field, and this is could be the reason why it
    is not working.
    I tryed some memory models added xhuge, but still no effect.
    So, i still need some help, how i could be overcome this problem.
    Thomas
  • Obviously, your program must have two different configurations: one for debugger mode (running from RAM) and the other for normal mode (running from flash). For that I use the multiple targets feature of uVision. You should specify the correct memory mapping for both configurations in the target options window (carefully check ROM and RAM ranges). Another important thing is that C startup file (start167.a66 or whatever it's called) is most probably different for the two configurations, so you need to check that too (external bus settings: BUSCONx and ADDRSELx - it is VERY IMPORTANT).
    For your first C166 project small memory model is the best choice as long as your code fits in 64K because you don't have to worry about xhuge modifiers and stuff like that. The small memory model allows you to have your code and data separated as far as you want in the address space (see C166 compiler manual).
    Good luck!
    Mike
  • The following answer book entry provides information on how to do this:
    http://www.keil.com/support/docs/2076.htm
  • Hi Support Intl Keil,
    first i have to say thank you for your help, but currently i have the
    feeling, sitting in the middle of nowhere. I could endless read all help
    files and so on, but i am not good, in inventing the wheel again.
    I have to go back to learn very basic thinks. For me it is much
    easier to learn new knowledge by example(s).
    I will searching the net for µV2 projects, which are well set up
    for my existing hardware.
    Thomas
  • You don't have to invent the wheel: the manuals describe in detail how it's done :-)) Look into the microcontroller manal as well as Keil's PDFs and you will find the answers to all your questions. Reading the manuals takes some time but sooner or later you'll have to do it.
    Regards,
    Mike
