Multi-tasking...
I want to read a character input from the keyboard so I used..
getchar();
The problem is, I want to be able to continue on with my program if user does not enter any character from the keyboard. The solution I have in mind is to do multi-tasking, but I am not sure if 8051 supports it. Also, I know that in C++, there is a function called..
peek();
This will return out of its function if a key is not pressed. So I want to know if C has a function similar to this...
thanks
Tommy
  • funny. I thought nobody used getchar()
  • Maybe RTX51 Tiny is the answer of your question.
    However, I found it too restrictive on calling same function from several tasks (even if the function is reentrant).
    Maybe RTX51 is the solution, but I wrote a simple scheduler which runs the registered functions with the given periods. This way I can check the keyboard for hits and debounce the keys.
    But, I do not know if this is the proper way.
  • Just write your own character fetch routine (http://www.8051.com has a multitude of suggestions). If you are not doing something complicated, do not consider an RTOS it will - if character fetch is your only problem - give you more headaches than writing a character fetch routine. You can write the routine to return 0 or ff if no char is available, if all 256 codes are possible make a global flag character_present set by character fetch, reset by "main"
    Have fun,
