Hi, I have a small project which carries out memory testing when loaded into my target hardware (C165 Based). At the moment, I have to hard-code the address at which the memory test starts testing and the range of memory to be tested. This involves re-building each time I wish to execute the test on a different area of memory, or different device. A colleague is creating a custom 'monitor' which will 'locate' the test code in a designated area and run it, however we would like to know how we could pass the above parameters (start address, range) to the test code, thus avoiding rebuilding the code each time. I think what I'm asking is how I pass parameters to 'main' when the code is being loaded into the target. If this is a ludicrous suggestion, I apologise! Many thanks....James
You could declare a variable in ram at a fixed location using the linker. If you download as intel or motorola hex, you could probably make the change by modifying a single line in the hex file. For example, I have declared a CRC variable at address 0xdffe. I add a hex record to the end of my hex file which initializes this variable with the crc of my code to be used during self test. :02DFFE00B74921
One way of doing this is to have those parameters stored in 'ROM' space (as const variables). You could modify them in HEX-files directly (if you know where they are located) or by means of some simple Windows program (home-made, of course). At least this doesn't involve rebuilding the project ...
Hi,<br> <br> I have a small project which carries out memory testing when loaded into my target hardware (C165 Based).<br> <br> At the moment, I have to hard-code the <br> address at which the memory test starts testing and the range of memory to be tested.<br> <br> This involves re-building each time I wish to execute the test on a different area of memory, or different device.<br> <br> A colleague is creating a custom 'monitor' which will 'locate' the test code in a designated area and run it, however we would like to know how we could pass the above parameters (start address, range) to the test code, thus avoiding rebuilding the code each time.<br> <br> I think what I'm asking is how I pass parameters to 'main' when the code is being loaded into the target.<br> <br> If this is a ludicrous suggestion, I apologise!<br> <br> Many thanks....James
Thanks for your help. We are overcoming our difficulty by using the 'monitor' to place the arguments we wished to pass in, into registers 8-11 just prior to executing the code. Thanks again....James
