89C51 programming
A real silly problem. I am currently learning how to program this guy, ATMEL 89C51. I had a LED on Port 1 pin 0. 4MHz crystal with 30pF caps to ground, resent to ground, grounded the uC, 5v to Vcc. And the my program can't compile.
#include <AT89X51.H>
#include <stdio.h>
int main()
int x,led;
sbit led = P1 ^ 0;
while(1)
{ led = 1;
for (x=0;x<10000;x++);
led = 0;
return(0);
..\test.C(7): error C141: syntax error near 'sbit'
Target not created
Someone tell me wats wrong? Do I have to configure the Ports ie. CWR? Like wat I have to do programming a 8255 PPI chip?
Thank you,
hengkc.geo@yahoo.com
  • Heng,
    Since you already have a led sbit declaration you don't need other variable with the same name. Your sbit declaration shoud be in a global area.
    #include <reg51.h>
    #include <stdio.h>
    sbit led = P1 ^ 0; //compilation time definition,
                       //it must be in the global area
    int main(void)
    int x;
    while(1)
    led = 1;
    led = 0;
    return(0);
    This should work...
  • Hi Alex,
    Thank you for your reply. I got the program to complie, but now a another problem. When I try to download into the uC, it prompts me Address out of range.
    I've seleceted the "Use on-chip ROM 0x0-0xFFF" option and everything could not complie again.
    Thank you in advance,
    Heng
  • Maybe you're using a Demo version... The Demo version will start your code at C:0x4000.:
    C:0x0000    024000   LJMP     C:4000
    C:0x3FFF    00       NOP
    C:0x4000    787F     MOV      R0,#0x7F
    Starting at 0x4000 your on chip ROM won't fit.
