XC164 CAPCOM6 unit
I'm new to the XC164 and microcontrollers.
I'm trying to setup the Capcom6 unit for a 100% PWM output on COUT60, 61 and 62. In debug mode (uVison2) the registers (under Peripherals T12, T13, CAPCOM6) are not updated when I single step my code. Could anyone help me with the right settings?
Best regards
/Daniel
  • Please have a look to INFINEON webpage
    - look for the APPNOTES
    AP1672 Dead Time Generation with CAPCOM6
    and
    AP1673 Details on CAPCOM6
    this was usefull to me, but have not tried with the new XC16x derivatives
    Stefan
  • Hi,
    I've got exactly the same problem! Did you find a solution to this? If so could you let me know!
    Thanks, Gavin.
  • Hi,
    I don't know which compiler version You use, but according to Keil, it wasn't possible to simulate the CAPCOM6 unit of the XC16x family at that time and that it would be a part of a software upgrade (April 2003). I haven't tried this update though, so I don't know if it works now.
    /Daniel
  • Hi Daniel,
    the appnotes are quite good, but take care, since the restrictions for 100% and 0% duty cycle are not valid anymore.
    A better description you cand find in the preliminary version of XC164, where this version is available on the web.
    CAPCOM6 support for XC16x is planned in KEIL's simulator approx. march/april 2004.
    You can simulate with old CAPCOM6 simulator dll, but this is tricky and you have translate some registernames to the new one
    according the manual.
    zero-match & parallel compare-match --> active state (CC6xR=0)
    zero-match wo compare match -->
    passive state (T12=0)
    A duty cycle of 0% is done as I know with reload of '0' and zero match without compare match enabled for T12.
    100% you can reach for my understanding by
    programming the wished period value + 1 and enabling both matches.
    For details have a look at peripheral manual.
    (xc164_um_per_v2.0._2003_12_pre_release)
    For some other reasons I have 2 examples written for simple edge aligne PWM and
    center aligned PWM dealing with shadowtransfer.
    (But not 0% and 100% duty cycle).
    If you are interested I can share the code.
    Best regards Stefan
  • Hi guys,
    Thanks for the update. I am using uVision 3 with the V5.00 compilier (the latest versions at time of writing).
    It is not easy to realise that a periferal isn't simulated. The other misleading thing is that the Timer12/CAPCOM6 debug windows don't update on either simulated OR ULINKed processor conditions. I thought I was going mad!
    The irony is that my code for timer 12 was working all along - To prove this I repeatly read the T12 counter into a variable then watched the variable count up and down in the debug enviroment.
    This seems to be the only way to debug T12/T13/CAPCOM6 stuff in ULINK for the time being.
  • Hi Gavin,
    that's one of the ways. I dealt with old CAPCOM6 (tricky) and if I got it working,
    I had a little bit more understanding.
    For debugging purposes I misuse a starterboard with hardwired CAPCOM6 outputs and an oscilloscope to see, whether the signalforms are the expected one or not.
    For simulation your way is surely more practicable.
    Stefan
  • Hello Stefan,
    can you please provide me the code ? Thank you in advance. My e-Mail: tipscho<at>gmx.de
    BR
  • Hi Andreas,
    I sent you 2 projects for startup.
    1 Edge Aligned Mode, 1 Center Aligned Mode.
    ( Simply output some signals to an oscilloscope )
    Stefan
