Find in files path in IDE
In uVision 2.06, when I want to "find in files", I can't figure out how to change the search directory and make it stick. The IDE seems to always want to start in the directory containing the uv2 project file, and I have to select the desired directory each time I do a "find in files".
Is there a way around this? My prior version remembered the path once it was set.
